CrowPanel Advance 5.0-HMI ESP32 AI Display
Model DIS02050A
advance-5.0
Version 1.0
Pin Output:
advance-5.0
SPK Output audio signals to connect to speakers. The main board comes with a power amplifier chip circuit. PH2.0-2P
PWR Power LED.
boot
UART0-OUT Builds communication between Logic modules, including the serial communication module and the print module. HY2.0-4P
UART1-OUT Builds communication between Logic modules, including the serial communication module and the print module. HY2.0-4P
UART0-IN 32 KB (ATmega328) of which 0.5 KB used by bootloader XH2.54-4P
I2C-OUT Establish communication between the microcontroller and peripheral devices. HY2.0-4P
BAT Connect the lithium battery. (with battery charging circuit)(3.7v-4.2v) PH2.0-2P
5.0-inch HMI port pin number Electrical Characteristics
UART0-OUT RX(IO44); TX(IO43) RX; Output voltage: 3.3V
Output current: 1A max.
Use: Power supply output and communication.
UART1-OUT RX(IO19); TX(IO20) RX; Output voltage: 3.3V
UART0-IN RX(IO44); TX(IO43) RX; Input voltage: 5V ± 5%. 5.5V max.
Input current: 2A max.
Purpose: Power supply input and communication.
I2C SDA(IO15); SCL(IO16) ; Output voltage: 3.3V
SPK I2S_LRCLK(IO6);I2S_BCLK(IO5);I2S_SDIN(IO4); Maximum output current: 20mA
Signal type: 3.3V logic level, digital control signal
SD Card Slot MOSI(IO6); MISO(IO4); CLK(IO5); CS(3.3V) Maximum output current: 20mA
LCD Backlight PCA9557PW-IO1 Maximum output current: 20mA
I2S MIC MIC_SD(IO20);MIC_WS(IO2);MIC_CLK(IO19) Maximum output current: 20mA
BUZZER IO8 Maximum output current: 20mA
Schematic:
ESP32-S3 and ISP Display Wiring Pins:
advance-5.0
ESP32-S3 and Touch Driver Wiring:
i2c address: 0x5D.
advance-5.0
ESP32-S3 and wireless module wiring pins:
advance-5.0
Schematic diagram of function selection:
advance-5.0
Switching Function Keys:
S1 S0 effective function
0 0 MIC&SPK
0 1 WM(wireless module)
1 0 TF Card
Version 1.1
Pin Output:
advance5.11-1
UART0-OUT RX(IO44); TX(IO43) RX; Output voltage: 3.3V Output current: 1A max. Use: Power supply output and communication.
UART1-OUT RX(IO19); TX(IO20) RX; Output voltage: 3.3V Output current: 1A max. Use: Power supply output and communication.
UART0-IN RX(IO44); TX(IO43) RX; Input voltage: 5V ± 5%. 5.5V max. Input current: 2A max. Purpose: Power supply input and communication.
I2C SDA(IO15); SCL(IO16) ; Output voltage: 3.3V Output current: 1A max. Use: Power supply output and communication.
SPK I2S_LRCLK(IO6);I2S_BCLK(IO5);I2S_SDIN(IO4); Maximum output current: 20mA Signal type: 3.3V logic level, digital control signal
SD Card Slot MOSI(IO6); MISO(IO4); CLK(IO5); CS(3.3V) Maximum output current: 20mA Signal type: 3.3V logic level, digital control signal
LCD Backlight P3.5(STC8H1K28) Maximum output current: 20mA Signal type: 3.3V logic level, digital control signal
Backlight Adjustment P1.1(STC8H1K28)
I2S MIC MIC_SD(IO20);MIC_WS(IO2);MIC_CLK(IO19) Maximum output current: 20mA Signal type: 3.3V logic level, digital control signal
BUZZER P2.7(STC8H1K28) Maximum output current: 20mA Signal type: 3.3V logic level, digital control signal
TP_RST P1.7(STC8H1K28)
advance5.11-2
0 0 MIC&SPK
1 1 MIC&TF Card
advance5.11-3
Schematic:
advance5.11-4
i2c address: 0x5D.
advance5.11-5
Version update points:
Version 1.1:
① Version 1.1 updated the control of backlight on the basis of the original, the backlight of version 1.1 is controlled by STC8H1K28 microcontroller, and the backlight is lit in the program by sending the value to this microcontroller address (0x30). The values are 0x05, 0x06, 0x07, 0x08, 0x09 and 0x10, where 0x05 switches off the backlight and 0x10 is the maximum brightness.
**To set a different brightness level, you must first send 0x10 to turn on the screen, and then send another value to adjust the brightness. **
The buzzer and speaker operate on the same principle as the backlight control: sending 0x15 activates the buzzer, while sending 0x16 turns it off. Sending 0x17 turns the speaker on, and sending 0x18 turns it off.
② Version 1.1has a new option for function switching, see above for details.
Version 1.2:
Version 1.2 introduces an updated backlight control function. In this iteration, the backlight is managed by the STC8H1K28 microcontroller. The programme illuminates the backlight by transmitting numerical values to the microcontroller's address (0x30). Brightness adjustment spans 0-245 levels, where 0 denotes maximum brightness, 244 represents minimum brightness, and 245 disables the backlight.
The buzzer and speaker operate on the same principle as the backlight control: sending 246 activates the buzzer, while sending 247 turns it off. Sending 248 turns the speaker on, and sending 249 turns it off.
Version 1.2: Other hardware and pin configurations remain unchanged. The button components have been updated; the buttons are now shorter, and the casing has been modified accordingly.
Platforms Supported
Arduino IDE ESP-IDF PlatformIO
Arduino ESP-IDF-Logo.webp platformIO
Arduino IDE View Tutorials -- V1.0
Arduino IDE View Tutorials -- V1.1/V1.2/V1.3
ESP-IDF View Tutorials -- V1.0
ESP-IDF View Tutorials -- V1.1/V1.2/V1.3
PlatfoemIO View Tutorials -- V1.0
PlatfoemIO View Tutorials -- V1.1
PlatfoemIO View Tutorials -- V1.2/V1.3
ESPHome SquareLine Studio Meshtastic
ESPHome View Tutorials -- V1.0
ESPHome View Tutorials -- V1.1/V1.2/V1.3
SquareLine Studio View Tutorials -- V1.0
SquareLine Studio View Tutorials -- V1.1/1.2/V1.3
Meshtastic View Tutorials
Only version 1.0 supports Meshtastic.
Thread Wireless ESP-matter
Wireless_Module-ESP32-H2 Wireless_Module-ESP32-H2
GetStarted GetStarted
Resources
Github link:
Code lib link:
Wireless link:
How to buy
Please visit this page to purchase ESP32 Display-5.0 inch(Advance_Series).
Support
