Transparent Acrylic Switches Tester Collection
This kit is designed to achieve the actual feel of a real Cherry MX switch mechanical keyboard by mounting all the actual switches on a specially designed model! The TRANSPARENT ACRYLIC SWITCHES TESTER will help you decide which switch is best for you.
It is compatible with 99% of the mechanical key switches on the market and can be customized into a mechanical keyboard that is unique to your own habits. Each switch is produced by the golden cross contact technology of the CHERRY factory in Auerbach, Germany, with sensitive reflection and quick response. And it has a high-precision precision switch. It can be knocked 50 million times and has a long life with strong spring. The MX key caps come with a dust cover to protect the internal parts and keep your key switches away from dust. And its built-in 3 mm LED lights which make your switch tester look cool.
Model: ACT23536L
- Accurate press feeling of 12 Cherry MX switches
- Stable housing, precise cutting frame
- Comfortable and smooth chauffeuring design on edge
- Translucent clear key caps
- Sensitive reflection, quick response
- Strong spring, super feel
- Has a lifespan of about 50 million strokes
- MX key caps with dust cover
- Detachable keys design for DIY
Specifications¶
| Item | Value |
| Color | Transparent |
| Size | 6cm x 8cm x 3cm (2.36in x 3.48in x 1.18in) |
| Material | acrylic housing |
Switch Color & Characteristics¶
| Switch Color | Characteristics |
| Cherry MX Red | Soft Linear 45cN - Smooth, no tactile bump |
| Cherry MX Black | Firm Linear 60cN - Smooth, no tactile bump |
| Cherry MX Blue | Tactile & Clicky 50cN |
| Cherry MX Brown | Soft Tactile 45cN - Softer & lighter tactile bump, no click |
| Cherry MX Green | Firm tactile & Clicky 80cN |
| Cherry MX Gray (black) | Tactile 80cN - Firm tactile bump, no click |
| Cherry MX Gray (brown) | Firm Linear 60cN - Tactile bump, no click |
| Cherry MX Clear | Tactile 55cN - Tactile bump, no click |
| Cherry MX White | Tactile & Clicky 65cN - Tactile and lighter click switch |
| Silent Red | Soft Linear 45cN - Smooth & Silent |
| Silent Black | Firm Linear 60cN - Smooth & Silent |
| Speed Silver | Soft Linear 45cN - Smooth, no tactile bump, 3.4 mm total travel distance only |
Shaft Changing¶
Notes: When inserting a new switch, please be sure to align the pin position, when it cannot be easily inserted, do not press it to prevent the pin from breaking
