AI Panda Chatbot with Intelligent Voice Control | Emotional Companion | Voice Assistant
Model AIB00101D
ai_panda_chatbot
Main Processor ESP32-S3N16R8
System memory 8MB Octal SPI PSRAM
Storage 16MB Quad SPI Flash
Display Size 1.28inch (R)
Display Panel Non-touch,Round shape, IPS Panel
Resolution 240×240
Bluetooth Supports multiple speeds (125 Kbps~2 Mbps) and broadcast extension, improving device connection stability and coverage (this product does not use Bluetooth).
WIFI Wi-Fi 4 (802.11 b/g/n): Supports the 2.4 GHz band, with a maximum speed of 150 Mbps, suitable for high-bandwidth IoT applications.
Button 1x AI Button for switching voice recognition;1x Switch button;
LED indicator light Full-color ambient lighting effects (voice control)
Size 62*60*32(mm)
Shell material 3D printed + silicone sleeve (with panda ears)
Net Weight 87g
Protection rating 1.5-meter drop protection rating (with silicone case)
Operating temperature -15°C to 50°C
Storage temperature -15°C to 50°C
Power input 5V input charging
Charging port Type-C Interface
AI Panda ChatBot Operating Instructions
ai_panda_chatbot-1
Power Button:
Click to turn the screen on or off; long press for 3S to power on or off.
AI Button
When the device is powering on, click to enter network pairing mode;
During device use, click to wake or exit AI function.
Operating Instructions:
1.Long press for 3S to power on and enter network pairing mode.
ai-panda-2
2.Open your phone/computer's WIFI list, click on AI_Panda_Chatbot-XXXX to enter WIFI pairing mode. Choose an available WIFI network, enter the WIFI password, and click “connect”.
ai-panda-3
  1. After connecting to the network, enter AI Hub Registration mode.
ai-panda-4
  1. Open a browser and go to https://portal.thinknode.cc/ to access the AI Hub interface. If this is your first time logging in, you need to click the "Create Account" button to create an account.
ai-panda-5
5.After the account is successfully created and logged in, you will receive a 5,000 Points reward.
ai-panda-6
6.Click the "AI Hub" button to start “Add Agent”.
ai-panda-7
7.Click “Add Agent” and give your AI Agent a name.
ai-panda-8
ai-panda-9
8.Click “Manage devices (0)”, then click “Add Device”, enter the verification code, and confirm.
ai-panda-10
ai-panda-11
9.After completing“Add Device”, you can configure charact
ai-panda-12
10 If you want to browse“Historical conversations”, you need to first enable “Local Short-term Memory”and save.
ai-panda-13
Video Presentation
Intelligent AI Panda Voice Chatbot
Spark Conversations with AI Panda: Your Voice-Activated Light Show Chatbot
How to buy
Please visit this page to purchase AI Panda Chatbot.
Support
