Nrf52840 AT Instruction Description Documentation¶
1, Summarize¶
The AT command is the initial setting for the default serial port used on the device. The default baud rate is 115200.
2, AT command format¶
AT commands have the standard format AT+XXX, where XXX indicates a command. There are four available command behaviors:
AT+XXX? provides a short description of the given command, e.g. AT+DEVEUI?.
AT+XXX is used to run the command, e.g. AT+VER.
AT+XXX=? Used to get the value of a given command, e.g. AT+CFS=?
AT+XXX=< value > is used to provide a value to a command, e.g. AT+CFM=1.
The output format is as follows:
AT+XXX=< value > < CR> < LF>
< CR > < LF > < Status < CR> < LF>
< CR > stands for “Carriage Return” and < LF> stands for “Line Feed”.
If no value is returned, no < value> < CR > < LF> output is returned. Each command (except for special planning) returns a status string that is preceded and followed by the format < CR > < LF> < Status < CR> < LF> .
Possible status codes include:
OK: the command ran correctly with no errors.
AT_ERROR: General error.
AT_PARAM_ERROR: One parameter of the command was in error.
3, AT Command Manual¶
1). general order¶
AT¶
This command is used to check if the communication is working properly
| command | input parameter | return value | Return code |
| AT | - | - | OK |
AT +APIVER¶
This command is used to check the lorawan protocol version number
| AT+HARDWAREVER | - | Lorawan protocol version | OK |
AT +HARDWAREVER¶
This command is used to check the hardware version number
| AT+HARDWAREVER | - | Motherboard version number | OK |
2). LoRaWAN Key and ID¶
AT+APPEUI¶
Description: Application Identifier
This command is used to access the unique application identifier in OTAA mode.
| AT+APPEUI? | - | AT+APPEUI:Get or set the application EUI (8 bytes, hexadecimal) | OK |
| AT+APPEUI=? | - | < 8 hex > | OK |
| AT+APPEUI=< Input > | < 8 hex > | - | OKAT_PARAM_ERROR |
typical example
AT+APPEUI=0102030405060708
OK
AT+APPEUI=010203040506070809
AT_PARAM_ERROR
AT+APPEUI=?
OK
AT+DEUI¶
Description: Device EUI
This command is used to access the unique terminal device ID. for OTAA mode.
| AT+DEUI? | - | AT+DEUI:Get or set device EUI (8 bytes, hex) | OK |
| AT+DEUI=? | - | < 8 hex > | OK |
| AT+DEUI=< Input> | < 8 hex > | - | OKAT_PARAM_ERROR |
typical example:
AT+DEUI=?
AT+DEUI=1122334455667788
OK
OK
AT+APPKEY¶
Description:Application Key
This command is used to access the application key in OTAA mode.
| AT+APPKEY? | - | AT+APPKEY:Get or set the application key (hexadecimal 16 bytes) | OK |
| AT+APPKEY=? | - | < 16 hex > | OK |
| AT+APPKEY=< Input > | < 16 hex > | - | OKAT_PARAM_ERROR |
typical example
AT+APPKEY=01020AFBA1CD4D20010230405A6B7F88
OK
AT_PARAM_ERROR
AT+APPKEY=?
OK
AT+NWKKEY¶
Description: network session key
This command is used for network session key in OTAA mode.
| AT+NWKKEY? | - | AT+NWKKEY:Get or set the application key (hexadecimal 16 bytes) | OK |
| AT+NWKKEY=? | - | < 16 hex > | OK |
| AT+NWKKEY=< input> | < 16 hex > | - | OKAT_PARAM_ERROR |
typical example:
AT+NWKKEY=01020AFBA1CD4D20010230405A6B7F88
OK
AT_PARAM_ERROR
AT+NWKKEY=?
OK
AT+DADDR¶
Description: device address
This command is used to access the device address in ABP mode.
| AT+DEVADDR? | - | AT+DEVADDR:Get or set device address (hexadecimal 4 bytes) | OK |
| AT+DEVADDR=? | - | < 4 hex > | OK |
| AT+DEVADDR=< Input > | < 4 hex > | - | OKAT_PARAM_ERROR |
typical example:
AT+DEVADDR=01020A0B
OK
AT+DEVADDR=?
AT+DEVADDR=01020A0B
OK
AT+FNWKSKEY¶
DESCRIPTION: Key for device to network server message integrity.
This command is used to verify the key for message integrity from the device to the network server (Node to Network Server).
| AT+FNWKSKEY? | - | AT+FNWKSKEY:Get or set the application session key. | OK |
| AT+FNWKSKEY=? | - | AT+FNWKSKEY=< 16 hex > | OK |
| AT+FNWKSKEY=< Input > | < 16 hex > | - | OKAT_PARAM_ERROR |
typical example:
AT+FNWKSKEY=01020AFBA1CD4D20010230405A6B7F88
OK
AT+FNWKSKEY=?
OK
AT+SNWKSKEY¶
DESCRIPTION: Key for device to web server message integrity.
This command is used to verify the key for subsequent message integrity from the device to the web server.
| AT+SNWKSKEY? | - | AT+SNWKSKEY:Get or set the application session key. | OK |
| AT+SNWKSKEY=? | - | AT+SNWKSKEY=< 16 hex > | OK |
| AT+SNWKSKEY=< Input > | < 16 hex > | - | OKAT_PARAM_ERROR |
typical example:
AT+SNWKSKEY=01020AFBA1CD4D20010230405A6B7F88
OK
AT+SNWKSKEY=?
OK
AT+NWKSKEY¶
This command is used to get or set the network session key in ABP mode.
| AT+NWKSKEY? | - | AT+NWKSKEY:Get or set the application session key. | OK |
| AT+NWKSKEY=? | - | AT+NWKSKEY=< 16 hex > | OK |
| AT+NWKSKEY=< Input > | < 16 hex > | - | OKAT_PARAM_ERROR |
typical example:
AT+NWKSKEY=01020AFBA1CD4D20010230405A6B7F88
OK
AT+NWKSKEY=?
OK
AT+APPSKEY¶
Description: Application session key
This command is used to set the application session key in ABP mode.
| AT+APPSKEY? | - | AT+APPSKEY:Get or set the application session key. | OK |
| AT+APPSKEY=< Input > | < 16 hex > | - | OKAT_PARAM_ERROR |
typical example:
AT+APPSKEY=01020AFBA1CD4D20010230405A6B7F88
OK
AT_PARAM_ ERROR
3). LoRaWAN network management¶
AT+TYPE¶
Description:Select LoRaWAN admission method
This command is used to join the LoRaWAN network admission method.
| AT+TYPE=< Input > | - | - | OK |
typical example:
AT+TYPE=2
OK
4). LoRaWAN Joining and sending¶
AT+JOIN¶
Description: join LoRaWAN network
This command is used to join LoRaWAN network.
| AT+JOIN=< Input > | < Param1 > Param1 = 0:ABPParam1 = 1:OTAA | - | OK |
typical example:
AT+JOIN
OK
AT+SEND¶
Description: Send Data
This command provides a method of sending data on a dedicated port number.
| AT+SEND=< Input > | < port > :< payload > :< msg > | - | OK |
typical example:
AT+SEND=10:0:12345
OK
AT+ ADR¶
Description: adaptive rate
The data adaptive rate that this command is used to access.
| AT+ADR=? | - | AT+ADR=(0 or 1) | OK |
| AT+ADR=< Input > | 0 or 1 | - | OK |
typical example:
AT+ADR=?
AT+ADR=1
OK
AT+ DR¶
Description: data rate
This command is used to pick up and configure the data rate setting.
| AT+DR=? | - | AT+DR=< Input > | OK |
| AT+DR=< Input > | < Input > | - | OK |
typical example:
AT+DR=?
AT+DR=3
OK
AT+DR=2
OK
AT+ DCS¶
| AT+DCS=? | - | AT+DCS=< Input > | OK |
| AT+DCS=< Input > | < Input > | - | OK |
typical example:
AT+DCS=?
AT+DCS=1,1250
OK
AT+DCS=1,1250
OK
AT+ TXP¶
Description:Set Transmit Power
This command sets the transmit power.
| AT+TXP=? | - | AT+TXP=< Input > | OK |
| AT+TXP=< Input > | < Input > | - | OK |
typical example:
AT+TXP=?
AT+TXP=22
OK
AT+TXP=22
OK
AT+ RX2DR¶
| AT+RX2DR=? | - | AT+RX2DR=< Input > | OK |
| AT+RX2DR=< Input > | < Input > | - | OK |
typical example:
AT+RX2DR=?
AT+RX2DR=5
OK
AT+RX2DR=5
OK
AT+BAND¶
Description:Set frequency band
This command is used to set the frequency band.
| AT+BAND=? | - | AT+BAND=< Input > | OK |
| AT+BAND=< Input > | < Input > | - | OK |
typical example:
AT+BAND=?
AT+BAND=1
OK
AT+BAND=1
OK
No relevant api commands found Reference is to LoRaWAN® AT commands for STM32CubeWL - Application note official command set.
| command | functionality |
| AT+CLASS | Sets/gets the LoRa class |
| AT+JN1DL | Sets/gets the join delay on Rx window 1. |
| AT+JN2DL | Sets/gets the join delay on Rx window 2. |
| AT+RX1DL | Sets/gets the delay of the Rx window 1. |
| AT+RX2DL | Sets/gets the delay of the Rx window 2. |
| AT+RX2FQ | Sets/gets the frequency of the Rx window 2. |
OTAA network access command
AT+APPEUI=89:89:89:89:89:89:89:89
AT+DEUI=78:78:78:78:78:78:78:78
AT+APPKEY=61:69:2A:12:8D:87:8A:3C:E0:52:0E:A2:87:F7:F8:F9
AT+NWKKEY=4F:EA:84:A3:6C:11:EB:C5:0E:C0:F3:43:6F:87:F4:D1
AT+TYPE=2
AT+BAND=1
AT+JOIN
AT+SEND=10:0:1234
ABP network access command
AT+DADDR=26:0B:81:2B
AT+FNWKSKEY=A2:93:5B:94:80:B0:79:80:C0:E0:F0:EA:E2:65:3E:8C
AT+SNWKSKEY=E7:FB:34:04:5E:4B:EC:AE:0B:37:00:BF:44:12:74:E5
AT+NWKSKEY=BE:C4:A8:63:3B:37:92:07:2C:D1:40:D6:5B:FB:A7:18
AT+APPSKEY=CA:F6:DB:11:A8:D1:BD:E1:52:16:38:F0:32:83:24:1D
AT+TYPE=1
AT+BAND=1
AT+JOIN
AT+SEND=10:0:1234
