5.0 Inch HDMI-Compatible Display for Raspberry Pi Compatible with Jetson Nano, Beaglebone
This is a 5-inch monitor with 800*480 resolution and four corner holes that allow you to mount the monitor to other devices. The back of the monitor is also equipped with 4 nut seats for mounting and fixing the Raspberry Pi. Comes with headphone port and speaker jack. Using a capacitive USB touch screen, you only need to power on the USB touch port to realize the touch function without installing a driver. Plug and play. The signal goes through the hdmi port. Compatible with multiple devices.
Model: DIS05490T
- 5.0inch lcd screen with 800*480 resolution
- Capacitive touch operation
- Speaker and headphone jacks
- Compatible with multiple operating systems (Raspbian, Ubuntu, Windows, Android, MAC OS and Chrome OS)
- Plug and play, no driver installation required
- Four nut mounts on the back for easy Raspberry Pi installation
- Touch type: 5-point capacitive touch
- Resolution: 800*480
- Brightness: 300cd/m²
- Display Type: TN Panel
- Screen: TFT-LCD screen
- Display Driver IC: ILI6122 & ILI5960
- External Power Supply: DC5V-2A
- Switch: Toggle Up/Down/Switch
- Interface:Power Input & USB Touch Port, 4P Port Speaker, 3.5MM Headphone Port
- Product Size: 137*80*14mm
- Weight: 140g
