CrowPanel Advance ESP32 AI display with PlatformIO
Overview
The example tutorial is a PlatformIO project, which demonstrates how to create a new project using PlatformIO, display UI graphics with LVGL, and control the on and off of a small light bulb connected to the UART port of the Advance development board according to the touch input on the screen.
In this tutorial, the version of the SquareLine Studio software used for designing the UI interface is 1.4.2, the version of LVGL is 8.3.11, and the version of the PlatformIO plugin is 3.3.4.
1. Introduce platfromIO
PlatformIO is a powerful open-source embedded development platform that provides developers with a one-stop solution. It has excellent cross-platform compatibility and can run seamlessly on various operating systems such as Windows, Mac OS, and Linux. This platform supports integration with mainstream IDEs like Visual Studio Code and Eclipse, enabling developers to work efficiently in a familiar environment.
PlatformIO boasts a wealth of library and sample code resources, which significantly reduces repetitive development work and accelerates the project development process. It standardizes the development processes for different hardware platforms and encompasses functions such as project management, code editing, compilation, uploading, and debugging. Whether it is for the development of Internet of Things (IoT) devices, embedded system development, or teaching practices in the field of education, PlatformIO can play an important role and is an ideal choice for embedded developers.
2. Install Visual Studio Code
Search for Visual Studio Code download on Google or enter the https://code.visualstudio.com/download, select the version compatible with your computer system and download Visual Studio Code installer. In this instructions we are selecting Windows.
Double-click the VSCodeUserSetup file to install the Visual Studio Code.
Accept the license agreement and go next.
Accept the default location or click 'Browse...' to change the installation location.
Accept the resting default option and click 'Next >...'
Click install and waiting for the installation ...
Click 'Finish' to exit the installation and (by default) launch Visual Studio Code:
Open Visual Studio Code and open Extension Manager.
Install Python
Search for 'Python' and install.
Install PlatformIO
Search for 'PlatformIO' and install.
Install Driver(Optional)
If you have not installed the USB driver, you need to install it:
https://www.silabs.com/developers/usb-to-uart-bridge-vcp-drivers
3. Introduce LVGL
4. Install SquareLine Studio
4.1 Installation Guide
Download the version 1.4.0
Click install.
Wait for installation.
Installation finish.
4.2 Software Function Introduction
Open the software
Note:Please select the corresponding resolution and color depth according to the screen specifications.
①Toolbar, including File, Export, and Help. Basic file operation bar, create or open files, export UI files and other operations. Click help and there are related introductory documents.
②Screen bar, the project screen will be listed here.
③Widget area, all widgets are here and can be selected and used according to project needs.
④Hierarchy area, it will show every widget used in each screen.
⑤This area shows the actual display effect, you can adjust the widgets or screen here.
⑥Material column, the added materials are displayed here.
⑦Setting bar, where you can make basic settings for each part, including the basic attributes and trigger operations of the part.
⑧Theme bar, different themes can be set.
5. Use SquareLine Studio to create UI control interfaces
5.1 Create a new SquareLine Studio project.
Here, I take a 2.8-inch screen as an example. After determining the resolution, I fill it in
Download of image resource files:
CrowPanel-Advance-5-HMI-ESP32-S3-AI-Powered-IPS-Touch-Screen-800x480/example/V1.2/arduino/lesson-03 at master · Elecrow-RD/CrowPanel-Advance-5-HMI-ESP32-S3-AI-Powered-IPS-Touch-Screen-800x480
The lamp-svg image size is available for both 2.4-inch and 2.8-inch screens.
table_lamp image sizes are available for 3.5-inch, 4.3-inch, 5.0-inch, and 7-inch screens.
5.2 Add functions to the buttons to enable them to turn on and off lights
Select 'event' to add in the right sidebar.
After selecting, click ADD.
After adding, run
5.3 UI interface design completed, exporting UI files for easy use in subsequent code
Click on Project Setting
Set export path.
Complete the setup and export file.
6. Create and run the PlatformIO project of this lesson
6.1 Create a new PlatformIO project
Double-click to open Visual Studio Code.
Click the PlatformIO icon, click QUIK ACCESS 'Open', then click '+New Project'.
Add a project name. Select "Espressif ESP32-S3-DevKitC-1-N8" for the board and Arduino for the framework.(In this lesson, the 2.8-inch development board is taken as an example.)
6.2 Add the necessary libraries to the PlatformIO project.
Click the PlatformIO icon, click ‘Libraries’, then search for the following libraries.
① Lvgl
② LovyanGFX
③ Adafruit SSD1306
④ TAMC_GT911
⑤ FT6336U
Click on the LVGL library.
Select version 8.3.11 (which needs to correspond to the version selected when creating the project in SquareLine Studio), and click "Add to Project".
Select the corresponding project name and click "Add".
If the library is successfully added to the project, the interface will automatically jump to the PlatformIO.ini file and automatically generate the project dependencies.
Note: If the platformio.ini file remains unchanged, but the library that has just been added is present in the pio->libdeps->esp32-s3-devkitc-1 folder, then click on "Compile". The PlatformIO plugin will pop up a window prompting you to change the library dependency link in the platformio.ini file.
Repeat the above steps and add the remaining libraries one by one (just select the latest version by default for the library versions).
After all the required libraries have been added, the PlatformIO project will be as shown in the following figure.
Place the lv_conf.h we provide to the path: .pio\libdeps\esp32-s3-devkitc-1-myboard in the project folder.
6.3 Add the chip configuration to the PlatformIO project
Open the platformio.ini file. This file is the configuration file of the PlatformIO project, which is used to define information such as the project's build environment, upload options, and library dependencies. Copy the following development board configuration into this file.
monitor_speed = 115200
board_build.arduino.partitions = default_8MB.csv
board_build.arduino.memory_type = qio_opi
build_flags =
-DBOARD_HAS_PSRAM
-mfix-esp32-psram-cache-issue
-DCONFIG_SPIRAM_SUPPORT=1
-DCONFIG_SPIRAM_TYPE=1
-DPSRAM_SIZE=2
-DPSRAM_CLK=120000000
board_upload.flash_size = 8MB
6.4 Add the necessary source files and header files to the PlatformIO project
Find the UI source files and header files generated by SquareLine Studio.
Copy the.c file in the UI file to the src folder of the PlatformIO project.
Copy the.h file in the UI file to the include folder of the PlatformIO project.
Similarly, add the display driver and pin definition header files to the include folder.
6.5 Write the main program in main.cpp
In PlatformIO, the.cpp file is an extremely crucial C++ source file. It serves as the core carrier for implementing program logic. It can define various functional functions to complete specific tasks, and it can also implement classes and objects, organizing the code with the object-oriented programming concept.
In terms of interacting with hardware, the.cpp file enables the writing of driver code to initialize, read from, and write to hardware devices such as sensors and actuators. Additionally, it allows for the writing of interrupt service routines to respond to hardware interrupts.
Moreover, the.cpp file supports modular development. Different functional codes can be encapsulated within it, which facilitates code reuse. In a multi-person team development scenario, different team members can be assigned to write different.cpp files, thereby improving development efficiency and the maintainability of the project.
6.6 Burn the well-written PlatformIO project into the CrowPanel Advance ESP32 AI display
Click the link below to download the code for PlatformIO in the corresponding size and version for use.
( 7.0-inch V1.2 5.0-inch V1.1 )
Code link:
CrowPanel-Advance-5-HMI-ESP32-S3-AI-Powered-IPS-Touch-Screen-800x480/example/V1.1/PlatformIO at master · Elecrow-RD/CrowPanel-Advance-5-HMI-ESP32-S3-AI-Powered-IPS-Touch-Screen-800x480
(7.0-inch V1.3 5.0-inch V1.2 4.3-inch V1.1 )
Code link:
CrowPanel-Advance-5-HMI-ESP32-S3-AI-Powered-IPS-Touch-Screen-800x480/example/V1.2/platfromIO at master · Elecrow-RD/CrowPanel-Advance-5-HMI-ESP32-S3-AI-Powered-IPS-Touch-Screen-800x480
Connect the light bulb at the UART1-OUT interface
UART1-OUT-interface
Select the corresponding serial port.
Click this button to build.
Wait for the compilation to be completed.
Click to burn.
Wait for the burning process to be completed.
So you can see the UI interface you just designed.
UI interface
You can click the On and Off buttons to control the on/off of the lights
buttons
Kind Reminder:
① Version 1.1 updated the control of backlight on the basis of the original, the backlight of version 1.1 is controlled by STC8H1K28 microcontroller, and the backlight is lit in the program by sending the value to this microcontroller address (0x30).
The values are 0x05, 0x06, 0x07, 0x08, 0x09 and 0x10, where 0x05 switches off the backlight and 0x10 is the maximum brightness.
**To set a different brightness level, you must first send 0x10 to turn on the screen, and then send another value to adjust the brightness. **
The buzzer and speaker operate on the same principle as the backlight control: sending 0x15 activates the buzzer, while sending 0x16 turns it off. Sending 0x17 turns the speaker on, and sending 0x18 turns it off.
You are currently viewing the 7-inch product of CrowPanel Advance HMI, and the version here is V1.3.
(For the 4.3-inch V1.1 version and the 5.0-inch V1.2 version, the following information also applies.)
In terms of hardware, we use a microcontroller (STC8H1K28) to control the screen backlight, speaker on/off, and buzzer.
Explanation:
  • 0x30 is the I2C address of the microcontroller (STC8H1K28).
  • 0x5D is the I2C address of the touch IC (GT911).
  • sendI2CCommand(0) means sending command 0 to the microcontroller (address 0x30) to instruct it to set the screen brightness to maximum.
For 0 mentioned above, you can replace it with the following values:
  • 0 is the brightest backlight.
  • 0 to 245: The screen brightness will gradually increase to the minimum value
  • 245 represents turning off the screen light
Additional notes:
You can also control the following functions by sending other instructions to the microcontroller:
  • It means sending the 248 command to the microcontroller (0x30) to instruct the speaker to turn on.
  • It means sending the 249 command to the microcontroller (0x30) to instruct the speaker to turn off.
  • You can also send command 246 to control the buzzer to turn on, and send command 247 to control the buzzer to turn off.
