CrowPanel ESP32 E-Paper 2.13-inch Arduino Tutorial¶
Overall¶
This tutorial will demonstrate how to use ESP32 E-Paper Display as a price tags and update price images through WiFi and Bluetooth. And how to obtain weather information and display it on ESP32 E-paper display. In addition, there are simple examples to illustrate how to use the various interfaces on the board.
Get Started with Arduino IDE¶
Demo 1 Update Pictures Wireless¶
This demo will introduce how to wireless update a single price tag through WiFi and Bluetooth.
Update via WiFi¶
Convert the image format¶
First, let's take a look at the price tag we design in this example, which is divided into three parts(all are images). The top bar is a fixed and unchanging background. On the left is the description, and on the right is the price. The parts we need to update are the description and price.
For the fixed top bar, we can convert it to C array and put them in the code.
For the variable description and price, we need to convert them to bin file and upload them to the board through WiFi.
Click open and select top-bar.bmp, convert it to array format.
- Open file
- Output date type: C language array by default
- The biggest width and height: Consistent with the width and height of the image. Note that it must be a multiple of 8, otherwise it cannot be displayed properly
- Select the output type as a C language array, set the scanning mode to horizontal scan, choose monochrome for the grayscale output, and flip the image horizontally.
- Do not include the image header data.
- Save and output
Generate a ‘.txt’ text file, then copy the C array code into the project that needs to use it.
Call the code in your project, and this will allow the image to be displayed on the screen.
Convert the description pictures and price tag pictures to bin files. These bin files will be used to update prices over WiFi.
- Open the file
- The output type select .bin file
- The width and height should consistent with the width and height of the image. Note that it must be a multiple of 8, otherwise it cannot be displayed properly
- Select the output type as a Bin file, set the scanning mode to horizontal scanning, and output grayscale as monochrome
- Save the file
Code Explanation¶
Please click
to download the code file 2.13_WIFI_refresh.zip for this demo.
Add necessary libraries
#include <Arduino.h> // Include Arduino core library file
#include "EPD.h" // Include library file for electronic paper screen
#include "Pic.h" // Include custom function library
#include "FS.h" // File system library for file operations
#include "SPIFFS.h" // SPIFFS file system library for file reading and writing
#include <WiFi.h> // WiFi library for creating and managing WiFi connections
#include <Ticker.h> // Ticker library for timing operations
#include <WebServer.h> // WebServer library for creating HTTP server
Define the file variable fsUploadFile Used for accessing files, txt_size and pre_size correspond to the size of the BIN file(Exported in the above steps) for the text label and price label to be transmitted. The image resolution requirement is smaller than the screen resolution and both width and height are multiples of 8.
// Define an array to store image data
extern uint8_t ImageBW[ALLSCREEN_BYTES];
#define txt_size 1728
#define pre_size 528
Note: The size here can be defined based on the size of the images to be transmitted later, otherwise it will cause image transfer failure
UI_price() Function
Check if the file system has saved UI images, and if so, display them.
void UI_price()
EPD_Init();
EPD_ALL_Fill(WHITE);
EPD_Update();
EPD_Clear_R26H();
EPD_ShowPicture(0, 0, 248, 24, gImage_top, BLACK); // Display gImage_scenario_home picture on the screen with black background
if (SPIFFS.exists("/txt.bin")) { // Check if file /txt.bin exists
// File exists, read its content
File file = SPIFFS.open("/txt.bin", FILE_READ); // Open file for reading
if (!file) {
Serial.println("Unable to open file for reading");
return;
// Read file data into an array
size_t bytesRead = file.read(txt_formerly, txt_size);
Serial.println("File content:");
while (file.available()) {
Serial.write(file.read()); // Print file content
file.close(); // Close the file
flag_txt = 1; // Set flag to indicate text file exists
EPD_ShowPicture(8, 36, 192, 72, txt_formerly, BLACK);
if (SPIFFS.exists("/pre.bin")) { // Check if file /pre.bin exists
File file = SPIFFS.open("/pre.bin", FILE_READ); // Open file for reading
if (!file) {
return;
size_t bytesRead = file.read(price_formerly, pre_size);
flag_pre = 1; // Set flag to indicate price file exists
EPD_ShowPicture(159, 56, 88, 48, price_formerly, BLACK);
EPD_DisplayImage(ImageBW);
EPD_PartUpdate();
EPD_Sleep();
okPage() Function
Receive the bin file sent and determine if it matches the pre-set file size. If it matches, store it in the file system and update the display icon.
// Function to handle file upload requests
void okPage()
server.send(200, "text/html", HTML_OK); // Send success page
HTTPUpload &upload = server.upload(); // Get the uploaded file object
// Note: The initial size of upload.buf is only 1436 bytes. Adjust it to support large file uploads.
// Modify the HTTP_UPLOAD_BUFLEN definition in WebServer.h to increase the initial size to 30000 bytes.
// C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.10\libraries\WebServer\src
if (upload.status == UPLOAD_FILE_END) // If file upload is complete
Serial.println("draw file");
Serial.println(upload.filename); // Print the uploaded file name
Serial.println(upload.totalSize); // Print the total file size
// Determine file type based on file size
if (upload.totalSize == txt_size) // If file size is 1008 bytes, it's a txt file
filename = "txt.bin";
else
filename = "pre.bin"; // Otherwise, it's a preview file
// Save the received file
if (!filename.startsWith("/")) filename = "/" + filename;
fsUploadFile = SPIFFS.open(filename, FILE_WRITE); // Open file in write mode
fsUploadFile.write(upload.buf, upload.totalSize); // Write file data
fsUploadFile.close(); // Close the file
Serial.println("Save successful");
Serial.printf("Saved: ");
Serial.println(filename);
// Store data in the appropriate array based on file size
for (int i = 0; i < txt_size; i++) {
txt_formerly[i] = upload.buf[i];
Serial.println("txt_formerly OK");
flag_txt = 1; // Set flag to indicate txt file has been uploaded
else
for (int i = 0; i < pre_size; i++) {
price_formerly[i] = upload.buf[i];
Serial.println("price_formerly OK");
flag_pre = 1; // Set flag to indicate preview file has been uploaded
UI_price();
// EPD_HW_RESET();
// EPD_ShowPicture(0, 0, 24, 152, gImage_top, WHITE); // Display gImage_scenario_home picture on the screen with white background
// // Display the appropriate image based on file type
// if (upload.totalSize!= txt_size)
// EPD_ShowPicture(0, 0, 56, 104, price_formerly, BLACK); // Display gImage_scenario_home picture on the screen with white background
// else
// EPD_ShowPicture(30, 30, 56, 144, txt_formerly, BLACK); // Display gImage_scenario_home picture on the screen with white background
// EPD_Display(ImageBW);
// EPD_FastUpdate();
// EPD_DeepSleep();
Image Refresh Process
Initialization
Select the data to refresh
Update the image to the screen
Upload the Code¶
Click "Tools"->"Board"->"esp32"->"ESP32S3 Dev Module", and the "Partition Scheme" select "Huge APP (3MB No OTA/1MB SPIFFS)", "PSRAM" select "OPI PSRAM".
Connect CorwPanel to the computer, click on "Tool" and select the corresponding "port".
Click "Upload" to upload the code to the board. There will be an image show on the screen.
Update the price tag with WiFi¶
Connect a laptop to the hotspot of the ESP32 E-PAPER display.
Enter the IP address 192.168.4.1 in the browser.
Select the bin file of the picture you need to show, then click submit.
Note: The size of the images you transfer must be consistent with the size defined in the code, otherwise it will cause image transfer failure
After successful transmission, the price and text will be replaced, and the data will be saved in flash.
Update via Bluetooth¶
The same as the method in the "Update via WiFi".
Code Explanation¶
Please click
to download the code file 2.13_ble_refresh.zip for this demo.
#include "BLEDevice.h" // BLE driver library
#include "BLEServer.h" // BLE bluetooth server library
#include "BLEUtils.h" // BLE utility library
#include "BLE2902.h" // Characteristic add descriptor library
#include "EPD.h"
#include "Pic.h"
#include "SPIFFS.h" // SPIFFS file system library for file read and write.
File fsUploadFile; // File object for uploading files
// Image buffer to store black and white image data
unsigned char test1[ALLSCREEN_BYTES]; // Array for storing file data
ble_pic function
Process the bin file sent and determine if it matches the pre-set file size. If it does, store it in the file system and update the display icon.
// Process BLE data and save it to a file.
void ble_pic()
// Check if data has been received.
if (dataReceived) {
// Ensure the data buffer is not empty.
if (!dataBuffer.empty()) {
size_t bufferSize = dataBuffer.size();
Serial.println(bufferSize);
// Determine the filename based on the size of the received data.
if (dataBuffer.size() == txt_size) {
} else {
// Ensure the filename starts with a slash.
if (!filename.startsWith("/")) {
// Open the file for writing.
if (!fsUploadFile) {
Serial.println("Failed to open file for writing.");
return;
// Write the received data to the file.
fsUploadFile.write(dataBuffer.data(), dataBuffer.size());
Serial.println("Saved successfully.");
Serial.printf("Saved:");
// Store the received data in the appropriate array.
if (bufferSize == txt_size) {
txt_formerly[i] = dataBuffer[i];
} else {
price_formerly[i] = dataBuffer[i];
Serial.println(" price_formerlyOK");
// Display the price interface.
UI_price();
// Clear the buffer after writing.
dataBuffer.clear();
totalReceivedBytes = 0;
ble_pic function
void clear_all()
// Initialize the display.
EPD_Init();
// Fill the display with white.
// Update the display.
EPD_Update();
// Clear the display.
EPD_Clear_R26H();
// Put the display to sleep.
EPD_Sleep();
class MyCallbacks : public BLECharacteristicCallbacks
Receive the data sent and integrate it together. Receiving the "OK" character indicates that the transmission is complete.
// BLE characteristic callback class
class MyCallbacks : public BLECharacteristicCallbacks {
void onWrite(BLECharacteristic *pCharacteristic) {
// Get the value received via BLE.
std::string value = pCharacteristic->getValue();
// If there is received data.
if (value.length() > 0) {
// Print a dot for debugging purposes.
Serial.printf(".");
// Assume the client sends a specific end marker ("OK") when data transfer is complete.
if (value == "OK") {
dataReceived = true;
return;
// Get the length of the received data.
size_t len = value.length();
if (len > 0) {
// Append the received data to the buffer.
dataBuffer.insert(dataBuffer.end(), value.begin(), value.end());
// Update the total number of received bytes.
totalReceivedBytes += len;
UI_price
// User interface function: Display price information.
void UI_price()
EPD_Init();
EPD_Update();
EPD_Clear_R26H();
// Display an image at a specific location.
// If the text file exists.
// Open the file for reading.
if (!file) {
Serial.println("Unable to open file for reading.");
return;
// Read data from the file into the array.
file.close();
// Display an image using the data from the text file.
// If the price file exists.
if (!file) {
return;
file.close();
// Display an image using the data from the price file.
// Display the image buffer on the display.
// Update a portion of the display.
EPD_PartUpdate();
EPD_Sleep();
Initialization
Upload the Code¶
Double click the 2.13_ble_refresh.ino.
Update the images via bluetooth¶
Download a BLE debugging assistant to your phone, and connect it your phone to the screen device BLE.
Upload the bin file(Save the bin file to your phone in advance).
Demo 2 Weather Station¶
Obtain weather information through OpenWeather and display the information on the CrowPanel.
Project Hardware Used
ESP32-S3 5.79-inch E-Paper Display.
UI Interface
The UI is composed of 5 parts:
Weather information
City information
Wind speed information
Temperature information
Visibility information
Humidity information
After converting the UI images into a C file, they can be used in the program for refreshing the display.
The resulting array can be directly copied into the project for use.
Add the necessary display driver libraries¶
Register an OpenWeather account¶
Enter https://openweathermap.org/ and click "Sing in" to register an OpenWeather account.
Log in your account.
Click your user name -> "My API Keys" to find your API key.
You can find the city codes at the following link: http://bulk.openweathermap.org/sample/
Please replace the information in the following code.
Code Explanation¶
Please click
to download the code file 2.13_wifi_http_openweather.zip for this demo.
Add libraries¶
#include <WiFi.h>
#include <HTTPClient.h>
#include <Arduino_JSON.h>
#include "EPD.h" // Include the EPD library for controlling the e-paper display
#include "pic.h"
Modify your information¶
const char* ssid = " "; // Enter your ssid
const char* password = " "; // Enter your WiFi password
// OpenWeatherMap API key
String openWeatherMapApiKey = "You-API"; //Enter your API key
// For example: String openWeatherMapApiKey = "bd939aa3d23ff33d3c8f5dd1dd435";
// Replace with city and country code you're in
String city = "London"; // City Name
String countryCode = "2643743"; // Country Code
Function Explanation¶
js_analysis
This function is mainly used to parse the received JSON data, process these data separately, and save them in variables.
void js_analysis()
// Check if you are successfully connected to a WiFi network
if (WiFi.status() == WL_CONNECTED) {
// Build the URL for the OpenWeatherMap API request
String serverPath = "http://api.openweathermap.org/data/2.5/weather?q=" + city + "," + countryCode + "&APPID=" + openWeatherMapApiKey + "&units=metric";
// Loop until you get a valid HTTP response code of 200
while (httpResponseCode != 200) {
//Send an HTTP GET request and get the response content
jsonBuffer = httpGETRequest(serverPath.c_str());
Serial.println(jsonBuffer); // Print the fetched JSON data
myObject = JSON.parse(jsonBuffer); // Parsing JSON Data
// Check if JSON parsing was successful
if (JSON.typeof(myObject) == "undefined") {
Serial.println("Parsing input failed!"); // Message when parsing fails
return; // Exit function if parsing fails
delay(2000); // Wait 2 seconds and retry
//Extract weather information from parsed JSON data
weather = JSON.stringify(myObject["weather"][0]["main"]); // Weather Master Information
temperature = JSON.stringify(myObject["main"]["temp"]); // temp
humidity = JSON.stringify(myObject["main"]["humidity"]); // humidity
sea_level = JSON.stringify(myObject["main"]["sea_level"]); // sea level pressure
wind_speed = JSON.stringify(myObject["wind"]["speed"]); // air velocity
city_js = JSON.stringify(myObject["name"]); // city name
// Print extracted weather information
Serial.print("String weather: ");
Serial.println(weather);
Serial.print("String Temperature: ");
Serial.println(temperature);
Serial.print("String humidity: ");
Serial.println(humidity);
Serial.print("String sea_level: ");
Serial.println(sea_level);
Serial.print("String wind_speed: ");
Serial.println(wind_speed);
Serial.print("String city_js: ");
Serial.println(city_js);
// Set the weather icon flag bit according to the weather description
if (weather.indexOf("clouds") != -1 || weather.indexOf("Clouds") != -1 ) {
weather_flag = 1; // cloudy
} else if (weather.indexOf("clear sky") != -1 || weather.indexOf("Clear sky") != -1) {
weather_flag = 3; // clear sky
} else if (weather.indexOf("rain") != -1 || weather.indexOf("Rain") != -1) {
weather_flag = 5; // rainy day
} else if (weather.indexOf("thunderstorm") != -1 || weather.indexOf("Thunderstorm") != -1) {
weather_flag = 2; // thunderstorms
} else if (weather.indexOf("snow") != -1 || weather.indexOf("Snow") != -1) {
weather_flag = 4; // snowy day
} else if (weather.indexOf("mist") != -1 || weather.indexOf("Mist") != -1) {
weather_flag = 0; // foggy day
else {
//If WiFi disconnects, prints a message
Serial.println("WiFi Disconnected");
// Functions that define HTTP GET requests
String httpGETRequest(const char* serverName) {
WiFiClient client;
HTTPClient http;
// Initialize the HTTP client and specify the server URL for the request
http.begin(client, serverName);
// Send HTTP GET request
httpResponseCode = http.GET();
// Initialize the content of the returned response
String payload = "{}";
// Check the response code and process the response content
if (httpResponseCode > 0) {
Serial.print("HTTP Response code: ");
Serial.println(httpResponseCode); //Print Response Code
payload = http.getString(); //Getting the response
else {
Serial.print("Error code: ");
Serial.println(httpResponseCode); // Print Error Code
// Release HTTP client resources
http.end();
return payload; // Returns the content of the response
UI_weather_forecast
Display the processed data saved in the variable on the screen.
// Function to display weather forecast on the e-paper display.
void UI_weather_forecast()
// buffer is used to hold formatted strings for display on the e-paper.
char buffer[40];
// Initialize the e-paper display.
EPD_Init();
// Fill the entire display with white color.
EPD_Update();
// Clear the display using a specific method.
EPD_Clear_R26H();
// Display a background picture on the e-paper.
EPD_ShowPicture(0, 0, 248, 122, pic, BLACK);
// Display the weather icon based on the weather_flag.
EPD_ShowPicture(1, 4, 144, 80, Weather_Num[weather_flag], BLACK);
// Display the city name on the e-paper.
memset(buffer, 0, sizeof(buffer));
snprintf(buffer, sizeof(buffer), "%s ", city_js);
EPD_ShowString(190, 30, buffer, BLACK, 12);
// Display the temperature on the e-paper.
snprintf(buffer, sizeof(buffer), "%s C", temperature);
EPD_ShowString(110, 110, buffer, BLACK, 12);
// Display the humidity on the e-paper.
snprintf(buffer, sizeof(buffer), "%s ", humidity);
EPD_ShowString(200, 72, buffer, BLACK, 12);
// Display the wind speed on the e-paper.
snprintf(buffer, sizeof(buffer), "%s m/s", wind_speed);
EPD_ShowString(30, 110, buffer, BLACK, 12);
// Display the sea level on the e-paper.
snprintf(buffer, sizeof(buffer), "%s ", sea_level);
EPD_ShowString(210, 110, buffer, BLACK, 12);
// Update the e-paper display with the new content.
// Perform a partial update of the e-paper display.
EPD_PartUpdate();
// Put the e-paper display into sleep mode to conserve power.
EPD_Sleep();
Initialization
EPD_Init();
EPD_Update();
EPD_Clear_R26H();
Select the data to be refreshed
Update the image on the screen
EPD_PartUpdate();
EPD_Sleep();
Upload the Code¶
Double click the 2.13_wifi_http_openweather.ino.
After downloading, the weather information for the city you have selected will be displayed on CrowPanel.
- Download the example
- Obtain the weather of the day through WIFI and update the UI. The UI information will change based on the received data
Examples for the CrowPanel Interfaces¶
Please click
to download the code file for the examples.
Instructions: Open the Example
Select the Flash Configuration
Perform Flashing
Example 1 BLE Example Effect¶
Select a BLE debugging app to search and connect.
Display after a successful connection.
Display when not connected:
Example 2 Count the times of pressing the keys¶
The screen displays the number of button presses in real time.
Example 3 Control PWR LED with menu Key¶
Press the menu button to control the power (pwr) light's on/off state, and display the status on the screen.
Example 4 Connect WiFi¶
After successfully connecting to WiFi, display the IP information on the screen.
Example 5 Screen full refresh¶
Refresh a full-resolution image on the screen.
