Lesson3 Use SquareLine Studio and LVGL libraries to create a UI interface to light the lights
Welcome to the third lesson of learning. I believe that after completing the last two lessons, everyone has gained a deeper understanding of our product. Next, I will lead you to the second application case of the Advance series products - Display the interface by calling LVGL technology and control the on - off state of the small light bulb.
1. Product Interface Introduction
Connect the development board to the computer with a Type-C cable.
Note: For the development boards with sizes of 2.4-inch, 2.8-inch, and 3.5-inch, the default interface for flashing is USB0.
For the development boards with sizes of 4.3-inch, 5.0-inch, and 7.0-inch, insert the small light bulb into the UART1-OUT port, and for development boards of other sizes, insert it into the UART-OUT port.
For the development versions with screen sizes of 4.3-inch, 5.0-inch, and 7.0-inch, the function select keys should be set to 0 1.
IDF-16
2. Introduce LVGL
3. Install SquareLine Studio
3.1 Installation Guide
Download the version 1.4.0
Click install.
Wait for installation.
Installation finish.
3.2 Software Function Introduction
Open the software
Note:Please select the corresponding resolution and color depth according to the screen specifications.
①Toolbar, including File, Export, and Help. Basic file operation bar, create or open files, export UI files and other operations. Click help and there are related introductory documents.
②Screen bar, the project screen will be listed here.
③Widget area, all widgets are here and can be selected and used according to project needs.
④Hierarchy area, it will show every widget used in each screen.
⑤This area shows the actual display effect, you can adjust the widgets or screen here.
⑥Material column, the added materials are displayed here.
⑦Setting bar, where you can make basic settings for each part, including the basic attributes and trigger operations of the part.
⑧Theme bar, different themes can be set.
4. Use SquareLine Studio to create UI control interfaces
4.1 Create a new SquareLine Studio project.
Here, I take a 2.8-inch screen as an example. After determining the resolution, I fill it in
The images can be found at the following location:
https://github.com/Elecrow-RD/CrowPanel-Advance-4.3-HMI-ESP32-S3-AI-Powered-IPS-Touch-Screen-800x480/tree/master/Squareline_studio%20Instructions%20for%20use/code
The lamp-svg image size is available for both 2.4-inch and 2.8-inch screens.
The table_lamp image sizes are available for 3.5-inch, 4.3-inch, 5.0-inch, and 7-inch screens.
4.2 Add functions to the buttons to enable them to turn on and off lights
Select 'event' to add in the right sidebar.
After selecting, click ADD.
After adding, run
4.3 UI interface design completed, exporting UI files for easy use in subsequent code
Click on Project Setting
Set export path.
Complete the setup and export file.
Then use VSCode to open the IDF project folder. Copy the generated .h and .c files into the corresponding folders of the project. (Here, I will use the code for the 3.5-inch version as an example, the download link is provided in Part 5.)
5. Compile and flash the code
Note: This lesson takes the code of the 2.8-inch display screen as an example. The version of IDF used is 5.1.1. For the LVGL display and touch functions, call the pre-integrated function libraries in the display screen code corresponding to the relevant size, and there is no need to download and install them by yourself.
Step1: You can click the link below to download the corresponding version of the code for this lesson.
(Lesson03)
Code link:
2.8-inch / 2.4-inch V1.0
https://github.com/Elecrow-RD/CrowPanel-Advance-2.8-HMI-ESP32-S3-AI-Powered-IPS-Touch-Screen-320x240/tree/master/example/V1.0/ESP_IDF
2.8-inch / 2.4-inch V1.1/V1.2
https://github.com/Elecrow-RD/CrowPanel-Advance-2.8-HMI-ESP32-S3-AI-Powered-IPS-Touch-Screen-320x240/tree/master/example/V1.1_and_V1.2/ESP_IDF
Select the code folder for this lesson, right-click on it, and then choose to open it with VS Code.
Step2: Select a serial port to connect to the development board.
Step3: Select the chip model "esp32s3".
Note: Since there is an sdkconfig.defaults file in the project, IDF can automatically recognize the development board configuration from this file, eliminating the need for manual configuration of the development board.
Step4: Click”build”.
Wait for the compilation to be completed.
Step5: Click”Upload”.
Wait for the flashing to be completed.
After flashing the program, tapping "ON" on the screen will turn the LED on, and tapping "OFF" will turn the LED off.
Kind Reminder:
Version 1.1/1.2 has been upgraded, optimizing the amplifier circuit for better sound quality and using only IO21 to control muting.
The i2s_mic is now controlled by two pins, IO9 and IO10.
