CrowPanel HMI| ESP32-S3 AI-Powered IPS Touch Screen connects to WiFi to play songs.
Welcome to the second lesson of learning. I believe that after completing the first lesson, everyone has gained a deeper understanding of our product. Next, I will lead you to the first application case of the Advance series products - connecting to WiFi to play songs.
1 Product Interface Introduction
The following interface was generated by introducing the official firmware of LVGL, and the specific operation will not be explained in this lesson for now. In the next class, we will mainly explain the LVGL graphics library. You can follow our updates to facilitate your learning.
2-1
2-2
2-3
2-4
Click the "Next" option.
git224
2 Download Git
Step 1: Open the official website of Git at https://git-scm.com/downloads/win.
Step 2: Click to download.****
git190
Step 3: After the download is complete, double-click the installation package to install it.
git213
git224
Check all the options here and click "Next".
git240
After that, click "Next" with the default settings. ****
git253
Finally, click "Install" and wait for the Git installation to complete.
git262
Click "Finish".
git273
3 Install the ADF library and configure the compilation environment
Step 1: Open VSCode and click to download the ADF library.
git315
Note: If the download fails, you can install it manually according to the following steps.
Open the official website of Espressif: https://www.espressif.com.cn/en/node/1
git381
Jump to the page to download the official voice library.
git394
Download the ADF library.
git403
Create a new folder named "esp-adf" in the installation path of the IDF tool.
git437
git439
Unzip the downloaded ADF library compressed package, and copy all the files inside the compressed package into the newly created folder "esp-adf".
git483
Search for esp-sr and esp-adf-libs on GitHub, and download these two libraries.
git524
git527
git529
Unzip these two compressed packages, and copy the files inside them respectively into the two folders within "esp-adf" -> "components".
git578
After copying, it will be shown as in the following picture.
git588
git590
Step 2: Fix the security vulnerabilities, functional defects, etc. of FreeRTOS existing in IDF 5.2.
Note: Whether the ADF library is installed with one-click or manually, this step should be carried out to ensure that the audio link can successfully play the audio.
Open the "esp-adf" -> "idf_patches" folder in the installation path of the IDF tool, and copy the idf_v5.2_freetos.patch.
git750
The idf_v5.2_freetos.patch is usually a patch file for the FreeRTOS part in the Espressif IoT Development Framework (IDF) version 5.2.
Copy it to the installation location of IDF.
git860
Right-click in this level of the folder and select "Open Git Bash Here" to open the Git command-line interface.
git889
Copy the command "git apply C:/Users/12397/esp/v5.2_tools/esp-adf/idf_patches/idf_v5.2_freertos.patch" into Git Bash, and then press the Enter key to run it.
Note: The path in the command needs to be replaced with the actual path on your computer.
git1019
4 Select a match code for the screen
In this lesson, we use small sizes (2.4, 2.8, 3.5) as examples. You can download the corresponding size codes from the official website.
Step 1: Download the code for this lesson and open it with VSCode.
git1056
Step 2: Change the Wi-Fi name and Wi-Fi password.
git1080
Step 3: According to the actual screen size of the development board, modify the code initialization and the included header files.
git1120
Step 4: Change the pin definitions in the ADF library.
git1171
Change the pin definitions of the small-sized speaker to the following pin numbers.
git1189
Change the pin definitions of the large-sized speaker to the following pin numbers.
git1207
Step 5: Connect the development board to the computer, and select the corresponding COM port and the model of the development board in VSCode.
Note: For the large-sized development board, toggle the function select keys to 00.
git1289
Step 6: Compile the code and flash it to the development board. Click the compile button and wait for the compilation to finish.
git1324
git1326
Click the "Flash" button and wait for the flashing process to complete.
git1340
git1342
